Company Logo Shop Now
TractorLinks.com
Tractor Talk Discussion Forum
Ford 3000 carburetor problems
lowline_farmer
09-12-2019 08:00:12
I inherited a Ford 3000 tractor I'm looking for some help having carburetor trouble on the manifold side idle mixture screw does it go into the throat because I an see the idle mixture screw tip on the inside of throat when its all the way screwed in also does any body out there have any used fuel lines that will fit a Ford 3000 also I need the fuel pump pushrod thanks bob
Hobo,NC
09-13-2019 04:28:22
 Re: Ford 3000 carburetor problems in reply to lowline_farmer, 09-12-2019 08:00:12
If you ditch the Holley I would like to have it.
I have never had to replace the fuel lines on a 3000 if I did I would have made up a extra set to sell are just for stock.
Do you have the old lines...
Hobo,NC
09-12-2019 18:45:16
Whut steve said... I would make new lines no problem for me cuzz I can double flare them...
Holley's are a real simple carb nuttin to fix'N them other then its not your normal plug and play tractor carb that tractor folk like its more on the automotive side of carbs that a real carb man understands...
RBoots
09-13-2019 12:50:09
 Re: Ford 3000 carburetor problems in reply to Hobo,NC, 09-12-2019 18:45:16
Hobo, the problem I have found on most Holley's on the tractors is the brass accelerator pump piston wearing out the bore in the carb. I'm not gonna spend a bunch of money fixing that when I can still have a better carb for less money. I'm not a parts changer, or one brand specific for repairs, I know carbs pretty well aside from the carbs used on JD 2 cylinders. I can make those run, but don't know the differences between all of their different numbers. A month ago, I had 2 of every major brand tractor here for repair that aren't mine. Holley's never work good after a lot of hours. Work good on V8 automotive engines though where everything is replaceable.
RBoots
09-12-2019 17:54:09
Funny, I also agree that the Holley carbs on Ford's, Olivers, John Deere, (trying to remember what other brands I've worked on and had to replace them??) are junk once the accelerator pump bore gets worn. It always goes like this: you can get it to idle good but won't take throttle well, or you can adjust that out of it so it will throttle up clean but won't idle smooth. We all agree they aren't much of a carb, and just to replace it with a Zenith, but there's always that one guy that will chime in and say that we're all just a bunch of idiots and those are great carbs, we just don't know what we're doing. In that case, there's a certain point of messing with something where it isn't worth the time or money saved where it's cheaper and easier to just buy a new carb that works as it should, unlike a wore out Holley carb.
Roy Prins
09-12-2019 17:13:56
A guy asked Me to get His ford to run -- sure I says,no problem -- YES problem - Holey junk-- I took it apart and looked at it real close -- what a piece of junk -- Replaced it with a different carb. and threw that piece of crap in the recycle pile -- Roy -- PS didnt bother putting it back together neither !!
Ultradog MN
09-12-2019 09:22:32
Those darned Holleys!
When I get one of those I pretend I'm Tom Brady and give it my very best heave into the nearest swamp, dumpster or scrap pile.
Then I come here to YT and buy a Zenith to replace it. Expensive yes but you won't be dinking with the carb for ever afterwards.
Especially since those 3 cyl Ford gassers aren't easy to work on in there.
And your tractor will RUN!
lowline_farmer
09-13-2019 03:53:11
 Re: Ford 3000 carburetor problems in reply to Ultradog MN, 09-12-2019 09:22:32
what model of Zenith carburetor do I need ? Are those aftermarket carburetor on E-BAY any good
Steve@Advance
09-12-2019 10:11:33
Ultradog, BTDT, I'll second the motion!
Those Holly (any Holly IMHO) are nothing but trouble.
Not often I let one defeat me, but those are real hard to make work.
The new Zenith was the answer.
3000OH
09-12-2019 14:29:14
 Re: Ford 3000 carburetor problems in reply to Steve@Advance, 09-12-2019 10:11:33
I second Steve’s motion and offer a third on Ultradog’s.
Ozlander
09-12-2019 08:51:30
I wouldn't expect it to be sticking out very much when adjusted correctly. Maybe someone screwed it in to far and enlarged to hole.
Steve@Advance
09-12-2019 08:13:00
It's normal for the tip of the screw to show coming through the hole.
As long as it's not a broke off tip stuck in the hole!
If it backs out with the screw, all is well.
What kind of carb problem are you having?
I like to use steel brake line for fuel line. Already comes with nice double flares on the ends. It forms easily, no bender necessary unless you need really close bends.
lowline_farmer
09-13-2019 04:04:38
 Re: Ford 3000 carburetor problems in reply to Steve@Advance, 09-12-2019 08:13:00
The problem is somebody took the fuel pump off all the lines and fuel pushrod and now they can't find them
lowline_farmer
09-12-2019 08:44:49
Its a Holley carburetor . I was going to rebuild the carburetor but it didn't look right with the needle mixture screw sticking out .
Steve@Advance
09-12-2019 10:13:01
 Re: Ford 3000 carburetor problems in reply to lowline_farmer, 09-12-2019 08:44:49
Oh... Holley.
Not good.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
