Had injector pump rebuilt, injectors rebuilt and still when tractor is started at first it knocks real bad, but in a short time will smooth out. What is my problem ?
Might be cold fuel knock? Might be timing,could
be worn bearings that takes time to get oiled
good
Is it making white smoke while its knocking? Could be low compression on one or more cylinders, that aren't firing till it gets warm.
(quoted from post at 02:40:03 09/04/19) Might be cold fuel knock? Might be timing,could
good
How many degrees forward should the timing be set on a 5000 Ford tractor.
