Radiator hose clamps
JimS
Which type of clamps do you prefer and why? Does the application matter on the type you choose?
I lean towed the worm gear/screw type adjustables. The spring type, particularly when they are old, I struggle with, plus, if they leak, you cannot give them the extra turn. Also, I find it easier to reach a screw driver or wrench into tight spots than a pair of pliers and try to rotate and pull.
Thoughts?
The spring type stay tight because they are self adjusting. But the worm screw type are easier to put on take off
I guess with the proper tool the spring type would be nice. I have been to cheap to buy one but will someday.
