DG1958
New User
Hello my first post, I have just finished putting my 3010 back together, i rebuilt the motor and added new clutches, all is running good so far except one small leak on the filter housing gasket. I was pressure washing the back of trans housing and i noticed a cover left of the vin plate and i am curious as to what this is for it dose not look to come off but it is bent out at the top. I had to replace all hydro oil as it had water in it, could water have gotten in through this plate.
Thanks Dave
I think you must be looking at the storage fixture for the PTO cover?
You can see the PTO cover in the storage location in the photo below.
<img src = "https://i.imgur.com/ThVihFf.jpg">
<img src = "https://i.imgur.com/u2gnwYv.jpg">
PTO shaft cover
Bob thanks so the piece that is there is for a pto cover to twist onto, i was seeing alot of grunge behind it and thought it might have gone into the trans. I will dig deeper into this.
Thanks for the response and the pic i have looked and the piece on the tractor is there to hold the cover on for the pto, i did not want to peel it off and have a bigger mess, it is good now. When i got the tractor it had sat outside partially un assembled and water had gotten in through open lines, i guess hydro is good still.
