Over time, as the grass growing next to the drive traps dirt and silt, the soil next to the drive seems to get higher and higher. This effects drainage and forms puddles even if I have initially a good crown. Is the best approach to scrape this away, or just keep dumping gravel on the drive to go deeper and deeper? It's very noticeable this year with all of the rain we've had. I suspect the driveway is also getting narrower due to this, but not at a noticeable rate.
I should probably blade it more often, but neglected it for several years and then put down gravel and bladed last fall and now again. I have access to a three-point mounted box scraper and a regular (not heavy, no down pressure) rear blade.
Thanks,
Thanks,
