pembinapasture
Good afternoon everyone,
I have an international 1066 that is in need of a clutch adjustment.
Little back story, I have had multiple issues with the MVC pump and the main hyd. pump, and have replaced the MVC pump and everything works as it should other then the clutch. When I removed the MVC pump, I had to remove the hydraulic booster and the linkages to the clutch, now I fear I have got the linkages out of wack. When I shift the tractor into gear it goes in good, no grinding or stickiness, but as I let the clutch out, it doesn't engage until the very end of the peddle and comes on with a lurch. It on or off it seems.
Now do I need to adjust the dump valve, linkage, TA linkage, not sure where to start. I have the manual, but since the tractor is so "tired" need to do it more by feel. Where would you guys start?
Thanks
Thanks
