IH model H or M
bfullmer
What is weight on front wheels with narrow front ? What do you guys use for temporary ramp to load on trailer ?
Sometimes you can run the tractor front wheel up one ramp and when it gets on the trailer make a sharp turn to line up the back wheels. It can be done.
All I ever do is put one ramp in the center drive up till the front end is up and stop. Then move the ramps so the rears are lined up and go the rest of the way on the trailer. Not rocket science it is common sense
Approximately 60% of the tractors total weight is on the rear, which leaves 40% on the front. For some tractors, the ratio might be closer to 70%-30%.
