Case 711B transmission leak or hydraulic leak?
Hey all, I'm new to the Case world. I just purchased a Case 711B and the owners told me that it has a transmission leak. From what I understood it was a pretty good leak. Any idea on what's leaking on the pictures I posted? My guess would be directly over the dead grass. Thanks in advance.
Most likely the seal on the pinion shaft. Drain oil, remove brake cover, which is the casting pictured, disconnect and remove brakes and you
will be at the seal. Use caution when installing new seal so as not to damage it during installation (easily done). A good opportunity to renew
brakes while you have them off.
I agree with Brad. Scroll down the Discussion forums to the CASE DB forum where the
Case guys hand out, and you will get more specific answers and detailed how-to info.
and sources for parts you need at reasonable prices.--------Loren
(quoted from post at 08:40:44 08/24/19) I agree with Brad. Scroll down the Discussion forums to the CASE DB forum where the
Thanks alot for the put gentlemen!
(quoted from post at 15:08:41 08/24/19)
Gentlemen, unfortunately the leak is coming out of the wrong side. It's coming out of the housing that the clutch pedal goes in, not the brake pedal side. Is there still the same seal on bolth ends?
