560D injector pump timing
Fritz Maurer
I was just curious as to why many different Diesel engine manufacturers, in many different configurations and displacements, the timing averages 18 to 26 degrees BTC, and the D236 and the D282 are 5 degrees BTC, according to the I-T manual. Thanks, Fritz
(quoted from post at 23:05:51 08/05/19) I was just curious as to why many different Diesel engine manufacturers, in many different configurations and displacements, the timing averages 18 to 26 degrees BTC, and the D236 and the D282 are 5 degrees BTC, according to the I-T manual. Thanks, Fritz
The specifications for some engines require them to be timed using "the start of injection", and others "the end of injection".
Likely, that largely explains the HUGE variations between the numbers you posted.
