Help me ID ford tractor
Beets
New User
I need help identifying this old ford
Thank you for your time!
Serial number is in pic but maybe a swapped rear?
Serial number is 820 then below is diamond 125916 and it has a3 point and PTO
820 is the model and by the serial number it's a 1957. An 820 wouldn't have originally had a PTO or 3 point hitch, so someone must have added them or like you said, maybe the rear was swapped out. Hope this info helps!
(quoted from post at 20:55:00 07/31/19)
So can you see the pictures? They are not showing on my device, I got the thing starting up great and running great but when I try to rev up RPMs it settles back down to high idle what should I try next to fix that?
No, I can't see the pictures either. I was just going by the numbers that you gave.
