Super C additional rear weights
Cmore
I recently purchased one set of additional rear weights for my Super C (thanks Paul).
What hardware or size bolts and how many per side do I need to properly mount? It has one set on it now. Thanks much.
The weights that are on the tractor, have four bolt holes. Remove two and put long enough bolts in those two holes to attach the addition weight.
3/4 of a inch.if your going to put on lets say 3 weights, you need 6 inches for the weight, 3 inch's for the center section,that's 9 and you need a inch for threads,so you need a 10 inch bolt, and there's nothing to it if you got two men, put one hand in the hand hold of the weight and the other hand around the tire for balance, lift it on the bolts, have a hammer handy to tap in the bolts a little farther, put the nuts on the outside of tractor is how i did it!
Going by Fastfarmall's figures. You will need bolts about 16-17 inches long and 3/4 size. so if you got some golden rod. You could put 2 in slide the weights up till you can tighen then cut in half or close to the nut and then use the other half for the other 2 bolts.
Golden rod is a grade 5 threaded rod. Been out for 50 years. My brother used to get it in Grand Rapids MI some place. So any industrial repair place should have it, or be able to get it.
No way Cat guy,for one more additional weight, he needs 3/4 x 8 bolts! 2 inches longer for each for each weight!
