"[b:654c4848f0][i:654c4848f0]Any idea what I should do to fix it?[/i:654c4848f0][/b:654c4848f0]"
Take a look at the [b:654c4848f0]CUTTER BAR, REGULAR[/b:654c4848f0] diagram below.
Note the rock guard(Key 36), ledger plate rivet(Key 37), and guard ledger plate(Key 38).
Take a look at your photo below.
Notice two ledger plates are missing.
Inspect every rock guard on the cutter bar.
If a ledger plate is missing, then either replace the rock guard or install a new ledger plate.
Note the outer shoe ledger plate(Key 41).
Inspect the the outer shoe and replace the ledger plate if necessary.
"[b:654c4848f0][i:654c4848f0]I do have an operators manual[/i:654c4848f0][/b:654c4848f0]"
Review your operator's manual section on how to register the knife.
Since the operator's manual was <a href="https://youtu.be/zytzhAxRVsY">published between 1936 and 1956</a>, the instructions may vary from one manual to another; however, the basic, fundamental method is still the same.
Review your operator's manual section on the alignment or lead of the cutter bar.
Review your operator's manual section on the knife hold-down clips and wear plates.
Review your operator's manual section on the cutter bar tilt adjustment.
Hope this helps.
