9.5X32 tires and rims
With the tires mounted cannot see the condition of the inside of the rim or if the hat band is still good. If rim is good with the hat band good that is a reasonable price for a show tractor that you wasnt to keep orignal that orignal came with the 32" tires. The ones saying that way too high are only correct in thinking for a useing tractor but not for that show queen as that hat band rim is not avaible any place new in either the 28" that replaced the 32" or in the 32" needed for a correct restoration for a show queen. And the 32" was only made for from 39 to 42 and most were changed out years before for the more traction 28" tire so iffing needing one for a show queen and it is good not a bad price but those are probably not being sold for a working tractor.
But the rim for that Ford does not fit the Deere unique only to the 39 to 42 Ford and then for a show only tractor and you could buy a replacement rim for that Deere for less as it would not be for a show only tractor and for that show only tractor as long as the tire holds up is what counts, they would only be used just to move the tractor around and not to do any work with.
