njdaveskiing
I'm splitting my MF150, AD3.152 diesel, multi power, at the engine/clutch housing due to oil presumably from input shaft seal leaks and oil on PTO clutch disc. I'll know when it's apart. As I loosened the bolts holding engine and clutch housing I started getting coolant dripping so I snugged the bolts up, and here I am. There is an intermediate plate casting about 1 1/2" thick between engine block and clutch housing. Does this plate cover a coolant port and is leaking? I cant find a diagram with this area in any manual. I know I can just unbolt and find out after draining coolant but thought I would ask here first.
