(quoted from post at 11:41:26 06/26/19) yes to all three. Take your time and watch the mail boxes.
(quoted from post at 13:16:40 06/26/19) I would not tow that 85 mi
rent yourself a trailer and do it right or pay a towing company to flat bed it
8 miles maybe not 85
(quoted from post at 11:26:17 06/26/19) It is to wide to fit on a trailer and not only that hen your hauling an oversized load not just a piece of farm equipment
That's because it's not true. As has been mentioned more than once.(quoted from post at 09:30:33 06/27/19)(quoted from post at 11:26:17 06/26/19) It is to wide to fit on a trailer and not only that hen your hauling an oversized load not just a piece of farm equipment
Yes, SV. that is what seems to be difficult for many people to grasp.
(quoted from post at 16:08:18 06/27/19) OK, now you have a whole lot of answers, many conflicting.
The thing to do is to call your state's DOT and see what your options and limitations are ACCORDING TO THE AUTHORITIES!!!!!!!!!
Advice you get here is worth exactly what you paid for it. Do it right.
(quoted from post at 16:18:43 06/26/19) There should be no reason it won't fit on an 8' trailer. And no reason it would be considered an "oversized load" in most states. Though I guess if we don't know the state it's something to think about. But I'd load it on a trailer and just get home.
(quoted from post at 05:54:02 06/29/19) Well as soon as you load it you will be an over size load. Now you need a permit flags signs and all the window dressing. If you just pull it you can do that with no problems. I live in MI also and was a motor carrier for many years. I would just take a couple spares heavier ones for the chamber side and go. 85 miles is not that far. Bearings are up to your comfort zone. I would just take the cap off put some Trans mission oil in and go. Oil will help soften any grease in there and keep them oiled.
SV is right about the Over size if loaded. If you stay off the interstate nobody will bother you. Earlier with the high temps will be better.
(quoted from post at 11:48:14 06/29/19)
Caterpillar guy, If you get an over-width permit as I did when going 130 miles, and they route you on the interstate as they did me, you may be in trouble if you are off the interstate.
(quoted from post at 03:14:41 07/02/19) Showcrop You are right. That is why I would just pull it and avoid the interstate. Loaded will have a route from the state on it you must follow.
