Andy Martin
Need help from the brain trust.
I've always heard you should balance 120v loads in a U.S. breaker box between the two phases coming in, and that balancing loads reduces the current through the neutral.
Got a friend who has a situation where he has two 15 amp motors on fans which he may run one or both. He wanted to use 12/3 w/ground and run each motor from separate legs of the box, basically run them on a 240v circuit but run them back on the neutral. He was concerned 30 amps would overload the neutral. I told him with two identical fans running on separate legs there would be practically zero current on the neutral.
Is what I'm saying actually true? I was basing the idea off of balancing a breaker box to limit neutral current.
