Valiant Farmer
Hi all,
I picked up a Fergy 28 awhile ago, and I finally got it running(after not for 9 months), and it ran OK, but a bit sputtery, but had enough power. Clutch was seized so would have to bump it into gear. I split the tractor, and replaced the clutch, and now it wont really run. I blew out the carb and fuel line, it has a good flow now, but it will only run at idle if you crank it enough. Try to gun the throttle and it dies with a sort of a sucking sound. I tried swapping the dizzy cap with no difference, only a good amount of missing and backfiring.
Any ideas? It was a boat tractor.
I am talking about The Grey Fergy - the purple one came with it - not running.
Thanks in advance!
Joshua
Thanks in advance!
Joshua
