John Deere 644 A loader
Does anyone know where to check and add transmission oil on a JD 644A loader? Also what oil is used in the transmission? I have a manual ordered but has not arrived. Thanks much
Center pivot should be a sight glass down tward the bottom if it is like its big brothers, 824 and 844. We run Shell Spirax S4 TXM at the mine in the Deere loaders.
I found the dip stick and it fills at the dip stick hole. I did have help, as the dip stick is on the floor in the cab behind the seat. If the design engineer would just check it once, he/she would find a more convenient location. Thanks for the replies, so much knowledge on this board. Thank-you
