Ford 801 remote hydraulic valve has back pressure when trying to activate. Keeps wanting to return to center before reaching detent position. Not much lift pressure.
Replaced valve because I thought there was an internal leak in the valve and had same issue with new valve.
There is also a leak at the right front mounting bolt. This happened with both valves and does not appear to be from between the valve and plate.
Replaced main relief under tractor,
Pump is rebuilt.
Any ideas [/b]
Pump is rebuilt.
Any ideas [/b]
