John Deere 2010 starter problems
hbyhayfrm
New User
Hi All, I have a 1960 John Deere 2010 that has developed an issue that when I am cranking the starter, it will only turn over for a few seconds then stop. After it stops I am not able to crank it over it for a few minutes. If I wait a few minutes it will then do the same.
Level which way???? Side to side or Front to back???? If front to back, you need to lengthen your 3rd link,
and raise your arms to carry the front, if front is digging in.---------Loren
Bad brushes will normally crank slower, a lot like a bad battery, but will start slow and stay slow.
You'll need to do some diagnostics.
A test light will be the easiest. Have an assistant operate the starter while you check for voltage at various points.
During the testing, be extremely aware that the engine could crank any time! Be sure the tractor is in neutral, stay clear of moving parts!
Have the assistant crank until the problem occurs, then hold the start switch while you check for voltage.
Check across the battery, the cable ends, positive post to ground. What you are looking for is any place that should have voltage, but doesn't under load. Also feel for heat, look for smoke, heat discoloration, corrosion. Check all the way to the starter cable connection. There should always be voltage between the top battery post of the starter and the starter case. If no power there, there is a bad connection, a loose cable, bad ground, etc.
Next check power to the "S" terminal on the solenoid. Ground the test light clip, check for voltage on the S terminal when the ignition in the start position. If no voltage, the problem is in the ignition switch, power to the ignition switch, the neutral safety switch, or a loose connection in that circuit.
If power to the S terminal, and no cranking, try shorting from the battery cable to the S terminal with a screwdriver or heavy wire. If that makes it crank, there could be enough voltage drop to not pull in the solenoid. If that is the case, get back with us, that is fixable, just involved.
If shorting the S terminal to the battery terminal does nothing, hold the starter switch to start, check for voltage on the starter post (the terminal that goes into starter case) to the starter case. If voltage there, and no cranking, there is an open circuit inside the starter. Most likely bad brushes, an easy fix.
Hope this helps, let us know...
I replaced the ignition switch and it now starts easier than it has in years. I opened up the old switch and it was all burnt out...Thank you all for your help!
