Grease gun end?
tomstractorsandtoys
Where can I buy a good quality grease gun end? I have a Lock-n-lube and like it but there are just a few fitting where it will not work. Is there such a thing as a good regular end? I asked my CaseIH dealer and he says there is no such thing anymore. Any recommendations? Thanks Tom
The case branded ones are good the John Deere brand ones are good also had good luck with the dewalt and Milwaukee brands
Lock n lube sells a kit with 2 adapters. 1 is a 90* and the other is a straight,narrow end. I use the 90* on several things. As far as a good regular end ,I've bought some from Napa. Mark.
One thing I have found. Change the fitting. Many times a new one is just a tiny bit better and does the trick. At the flea markets in car shows they sell a whole replacement end and hose for grease guns for around 5 bucks. They all have worked quite well.
I had to recently replace the hose on my Lincoln. Yesterday when greasing my hoe I removed a tiny fitting on the bucket, to see if grease was going through the fitting. When I went to remove the fitting from the hose end I COULD NOT GET IT OUT, even holding the fitting with vise grips. I had to thread the fitting back in. I am a believer now in replacing the end periodically.
