super99
I posted a while back about needing to take the angle attachment off of my Waldon blade. One
pin came out hard and the other one was stuck tight, looks bent. I cut the attachment off with a sawzall, now what to do about getting the pin out. The sleeve is welded thru the frame, so no way to get heat to it. I hit it with a hammer and punch a bit, but it just laughed at me. Wondering whether to try to cut pin out with the torch from the bottom, maybe if I can get part of the bent part cut out it will then drive out, or just put it up straight and weld it solid. Pics of the cut off pin are on my phone, I'll post them seperate. Any ideas??Thanks, Chris
