International 412B Scraper
autie81
New User
I am looking for a wheel seal on a 412B international Scraper year made 1986. We currently purchased it and are doing the minor repairs. We have pulled the seal and the number on it was 7516x54 national. I have called local dealers with case IH and other companies on-line with no luck or reference to that number. Any one have ideas that can get me in the right direction?
International held the rights to alot
of seals and bearings. You may have
to try a komatsu dealer as they
bought out International/dresser or a
Dresta supplier when they changed
hands again. Even in the 90,s some
parts were hard to come by.
If the old seal came out somewhat intact, or you can get some accurate (calipers) measurements of the bore, shaft size, and width range, take the seal and measurements to a bearing supply. They might can match it up.
Ford did the same thing after new holland merged and they dropped the ford name that made some ford tractor parts really hard to get ahold of
Thank you every one for the quick responses. I will see what I can come up with on the seal measurements that I have. I tried using a national book with the shaft size and OD of the seal. Came up with some numbers but are not longer available. I have not messed with these machines for parts as much as I have older Trucks. I will post something IF I happen to find a wheel seal equivalent to this one.
Again Thank you all
Autie Call Tony Collins when I sold my salvage yard all the new old stock parts went away but this boy has been working in IH parts for years , if anyone has one or know where to turn Tony will. Probably going to send you to FP Smith in California but call Tony at 731 225 0154
I will do found an old Navistar number 327240r91 which is discontinue found new old stock on-line $200.00. I will give him a call. I know its supply and demand, but $200.00 for that seal is a bit much. But if it last as long as this one (I am sure its never been changed) It would be worth it. But nothing is made like it used to be or so it seems.
