Riversedgefarms
Hi everyone im hoping someone here knows possibly what happened here. I was disking last night and the tractor felt ams acted like it slipped out of gear. When i went to reset the gear i found i have no gears in high or low range except for 9th gear which is the only gear to bypass the hi low selector. Now when i found that i had the road gear i ruled out the clutch and final drives as not the problem. Im assuming it has to do with the hi low range selector. As the rest of the gears shift fine it just wont move as if the transmission is in neutral. Any insight on this would help as i need this machine back up and running asap
