Ultimately determined my exhaust was clogged and why it wouldn't run on it's own and was spitting fuel everywhere. Small clip below of it running on its own for the first time in 35 years. Open manifold. No exhaust pipe on it. Giggled like a school kid.
Leaking water from under the pump pretty badly. Need to finish the wiring. Otherwise it seems to run good and I shifted through all gears (4 speed on the floor). Good oil pressure. Want to let it idle with some seafoam in it and then change oil/filter again, retorque head bolts and check/adjust valves.
I can't figure out how to embed a youtube video so here is a link. Hopefully it works.
https://youtu.be/QX-thwGifR4
