Lamont in NC
I'm working on an older 5hp horizontal shaft Briggs engine that's been sitting for years. It has the large metal tank with a long carb on top. The tank looked very clean inside with no rust but when the carb was removed the little bowl/container/thingie that is under the carb inside the tank--you know what I'm referring to--well it's rusted away with big holes in the bottom and sides. I'm not sure the purpose of this bowl and I'm hoping someone here can tell me what it's for and if per chance the carb will work with it missing or how I can fix it. Those tanks are expensive! Cheapest I've found is $78 and there is no way this is worth spending that much on.
