When I started rebuilding my Ford 640 I wanted to replace the clutch, pressure plate, pilot & throw out bearings. The reason was the clutch would jerk when it was feathered or slipped like doing precise work that require a gentle touch (pulling another stuck tractor out, dirt scoop or precise work). What caused this? The clutch plate or the pressure plate becoming warped due to heat?
Question 2:
After getting far enough along to install the new clutch and components and bolt the tractor back together I can only get 1& 1/2 inch of clutch pedal and a lot of free play. The new clutch kit came from YT and does not have the adjustable fingers or counter weights like the one I took out . Did the different style pressure plate cause this? Anything else I need to look for?
Question 2:
