RuralTowner
Need help ID'ing the specific name for a particular coupling type. Unfortunately I keep forgetting to get an image of the one I'm after from the Ditch Witch at work.
It's a sliding spline coupling. The inner portion is simply slides on a spline shaft. When a lever is moved it slides the coupling until it engages with another shaft. The outer ring is fixed and does not spin...it has a set of "trunions" on either side so the forks of the engaging arm to pivot on. The inner coupling spins inside the outer ring just like a sealed bearing does.
Got a project I'm trying to get started on and the most critical component...a disconnect meant to transmit power to a 3rd axle (tandem rear) that can be engaged//disengaged...depends on finding this specific PURPOSE built component. Otherwise it means piecing one together. I'd rather it be the former.
