Piston pin bushings
pburchett
Is it possible to ream piston pin bushings with an adjustable hand hone or reamer such as the generic photo below or do I just need to visit the machine shop
No, piston pin bushings are sized on a precision honing machine.
Not only is the size extremely critical, the bore must be held in exact parallelism to the crank end bore.
Both are impossible trying to hand ream.
You have to keep the reamer straight. On a side note I have a Sunnen hone for sale with lots of tooling. Some theory is the Sunnen hone imbeds grit into bronze bushings and reamers should be used.
I watched a machinist hone my 39 JD A pin bushings on a machine and he was holding the rods with his hands.
I have used reamers by hand putting new bushings in Model T transmissions. There are quite a few bushings in a T tranny.
Worked great. Just go slow.
Richard in NW SC
Depends. Is this on a show or hobby tractor that only sees 10 hours running per year? Better yet if this is a slow running engine. Or is this on your pu. that gets 50,000 miles per
yr.?
umm , all depends what u are working on, a patch job or precision job. its machine shop work and even temperature plays a roll in the fit. the same machine is used to resize the crank end also. I don't see how the average person can do it without the specialized measuring tools and equipment. the pin end is more a feel fit also.
