John Deere rims
What type of outer rear rims does John Deere use??
I found these tires local. They come with the rims.
What I need to know is if these outer rims will fit the 6 post centers off my ford 861.
Those DEERE rims are the "ribbed" type where the lugs grip the rib when tightened, and the rim can be relocated to adjust wheel spacing and the other rib clamped to, instead.
I would ASSUME the mounting lugs on your Ford rims are permanently attached, vs clamp-on and the rims won't interchange either way between the centers.
