Mahindra 6000 stuck in reverse part 2
old
So went and look at it. The owner had the top cover off the transmission and it appears that the reverse shifter fork is broken. So in the next few days I will be going to pick it up and haul it to my shop to try to fix it. First thing I need to do is find a manual for it. I is a 2006 Mahindra 6000. So where do I look for a manual then where do I find parts. This is way newer then I normally mess with.
Thanks
There is a used manual for a mahindra on eBay it?s on CD and it?s 200$ has service operators and parts manual . I. Can?t help you on parts some of those fly by night tractor companies are hard to get parts for
Untitled URL Link
Reverse shifter is broken, where? Can it be welded? A decent welder can make it fit and be stronger than original.
Don't block your shop door with it. Might be a year or more to get parts. I never hear anything good about those across the pond tractor brands except for the Kabota's seem to have figured that outpretty good from what I hear .
So far we have not found any of the broken parts. The guy drove it a long way in reverse to get it where it sits now.
Well there web site is not worth much. Did get the locla if you can call them that phone numbers but not able to pull up any parts lists etc.
I won't call one of the world's largest tractor manufacturers a "fly by night hard to get parts for". Yes, they are not as established in North America as some other off shore manufacturers but I don't think that parts would be a problem.
