Subject is a MF135 3 cyl gas perkins. No spark. I replaced the coil cap wires plugs condenser points and rotor arm. Coil gets power and I even tried a second coil in case I bought a bad one. I put a timing light on coil wire and it didn't light up.... so I suppose the coil isn't discharging. What should I look at next?
Tractor stopped running on me and that's when I decided to do overhaul on ignition system. So it didn't run prior to all my swaps. Prior it would run for a while and then shut off... I sorta thought it was a fuel issue and rebuilt the carb. But no spark is a clear problem.....
