Case 730 3pt
Koolie
New User
I have a Case 730 Comfort King and the 3 point arms won't raise. They worked good last fall. The tractor has a loader and it will lift the front end off the ground. The hydraulic valve under the platform is moving the spool but nothing happens. Thanks for any help.
We had something similar once and moved the draft control setting and everything worked after moving that, must have unstuck something. One other thing I had happen is a bolt fell out on the draft sensing linkage under the rear of the tractor directly above the swinging drawbar just a couple things to try that might help.
