Changing Hydraulic fluid in a White 2-60
Tonymac82
New User
Does anyone know where to access the drain port and fill port on a White 2-60 tractor? I have the manual but unable to locate anything regarding this. Thanks
It uses the transmission and rear end oil doesn't it? The fill plug is ahead of and to the left of the shift,next to the neutral switch. Takes a 7/8 wrench. My 1365 is the same thing I believe. Mine's a FWA and the plug is in the bottom of the transfer case,but there should be at least one plug right down underneath somewhere between the axle housings.
Two drain plugs front and rear right on the centerline of the main tranny housings. If you want to get rid of water in the hydraulic system remove the entire tube between the sump and the hydraulic pump up front. The same unit that holds the hydraulic oil filter. Follow instructions on page3-5 of your owners manual to clean the filter screen.
