I talked to you a while back about my Kubota b8200 not charging. After
we talked I went through the wiring again and found a bad wire going to
one of the fuses behind the panel near the clutch pedal. I am just working
on it again. I had some other more important things to take care of. I
also removed the galvanized bracket near the seat springs and cleaned up
all the mating surfaces so I am sure I have a good ground. Is there
another place the electrical system grounds to the frame ? I haven't run
across it yet. I'm just trying to eliminate simple fixes before I replace
the regulator and that's not it. Thank you for your help !
