ohiojim
any tricks to removing the clutch drive assembly, it's got a pretty good purchase on the crank. i've got a puller on it but it refuses to budge.
get tension on it and warm it with the torch, light heat, not surface of the sun, once its just a little bit warm and pressure on it it will pop right off
Don't pull on the outside of the driver, you'll break it. Use the 2 holes and thread bolts in them.
(quoted from post at 15:56:53 03/16/19) Don't pull on the outside of the driver, you'll break it. Use the 2 holes and thread bolts in them.
i use a 4 inch channel iron with some slotted holes.
