ford 3400 clutch release bearing hub
Norm Ring
New User
ford 3400 clutch release bearing hub with grease dispenser but the hub does not seam to have a exit hole toward the bearing or the support shaft. The old release bearing have a cutout for greasing. What size hole should there be
Maybe the grease fitting is just for the bearing support shaft lube, and not the bearing. The new bearing may be just a sealed bearing, and not lubed. Stan
Not the same unit but my 4500 has greaser on it. It greases the support and bearing. It took several fillings of cup to get it there.
