Diesel relief!
Many thanks for all the help with my David Brown 25D's fuel issues!
Had the tank professionally cleaned and the diesel still came out at a trickle, then found out that the tap was only just open...hope this might help someone!
Thanks!
Joshua
Well if I confessed all the times I had made a mistake like that in my career of mechanic work I?d have some tales to tell. At least you didn?t keep replacing parts until the problem went away . It won?t hurt that tank one bit to be cleaned and probably didn?t cost a whole lot to do either. I bought a tractor once that was misdiagnosed as having a bad engine the previous mechanic replaced a bunch of parts and still couldn?t get it to run which was fine by me I got a lot of new parts turned out that everything on the tractor was just out of adjustment
