JD 8300 crankshaft dampener
8850dave
My JD 8300 has under 6000 hours on it with an 8.1 motor should I replace original dampener now ?? Shows no sign of rubber detiorating at this time water pump and injection pump are being serviced now
I would while it is apart.i had to replace the crank in one that destroyed the end of the crank when it failed at7200 hours
I would replace it. I always recommended them to be replaced every 3000-4000 hours on the larger tractors.
I agree on replacing it.....it doesn't have many hours on it but the rubber doesn't care, it ages regardless of the tractor running or not
