(quoted from post at 20:05:38 03/03/19) When that tractor was new, the oil had 'zinc' in it. Camshaft needed it to keep from wearing out from the flat tappets. The zinc went away when it was discovered it clogged up catalytic converters. Now your tractor 'probably' doesn't have enough spring pressure to need it but until auto and truck engines got roller cams they sure do. Maybe someone with more info on valve spring pressure can chime in???
