Try a video
SVcummins
4020 cold start part one
[video play=false:654c4848f0]https://www.yesterdaystractors.com/cvvideos/cvvideo14940.mov[/video:654c4848f0]
You need to convert that mov to mp4 or webm in order to have it play in modern browsers. You can use ffmpeg which is a cross platform tool. It is command line, but very well documented and very easy to use. You can get it <a href="https://www.ffmpeg.org/">here</a>.
The mov format requires the quicktime plugin to be installed, and would need to be embedded as an object rather that as an HTML5 video element.
Interesting that the audio works though:)
You used 12 (twelve)terms in your post that I have not a jot or an inkling of which you are speaking (and I was an electronic tech with an associate degree) gettin' old is a b$#^h......................................gtm
