Tractor LED lights
Im sure someone has asked the question before, Ive got a 1979 935 Versatile that Ive been wanting to upgrade to a LED lighting system. Where do I find good lights without paying a arm and leg? Theres just so many options out there and Im sure theres someone on here thats more knowledgeable than I am with this. Im just looking for the round or square lights, I don't want to go with a light bar.
I don't have brand recommendation, but something to consider when making a selection, look at the mount.
That is one area that gets compromised with the cheap lights.
Sooner or later, it will take a hit. What will be the most likely thing to happen? Will it pivot back, or break the case or the bracket? Will it stay tight under normal use?
I have used Tigerlights. Not the cheapest but very knowledgeable.
https://tigerlights.com/c-1180034-versatilebuhler.html
Their catalog even has a section for Versatile. I suggest you call them and they can help you get the right light to both fit and have the correct functions, and correct connections.
Paul
Two fellas on the new ag talk web site sell lights, and have very good reputations.
A Larsen and a Peterson.
A little searching over there would get you some info.
Paul
I put a light bar on the front of our 1466 and a curved one on the back at the top of the cab. both work great for seeing. Though the front I want to put a couple of lights on the sides that shine out to the side so you can see better for planting with the drill or with no markers. I think for them I will just put a pair of halogens on. just as much light just draws a bit more juice.
Look at the lumens as you can get from candles to daylight in LED lights.
Mine came off amazon. I bought the more expensive ones for the size offered and they?ve worked very good. I paid less than a $100 for a huge light bar
and it makes a world of difference when working at night. One on front, one on back and some smaller ones out the side.
stonerock Yes they will I?ve got a set that I bought for the front of the truck couldn?t listen to the radio at night but I could see
