Power steering
TDJD
I got a Behlen power steering unit for my John Deere A. I have the JD live hydraulic pump and a priority valve so I can still run the Power-Trol. Do I need a relief valve or will this work? Also, can I run 30W oil in the power steering unit? Thanks.
Priority valve
I would add a relief valve. Also you do not need that large of a flow control! Do you know what the pressure is for the power steering and the Power Trol?
If you are plumbing the Behlen into the tractor hydraulic system, the Behlen will use the same fluid.
I have a Behlen unit on a Farmall H, but it has its own, dedicated pump. I use ATF, type F.
