Friday "Extra" Pic
kcm.MN
Location
NW Minnesota
Some of the stuff coming out of Europe is absolutely leaving us behind in the
dust. Looks twenty years ahead of anything they are putting out on this side of
the pond.
They have been 10 years ahead of us in comcept and design since the late forties. (MFD is a good example).
Tractors over there have more duties than pulling a plow or planter. They are geared for both field and highway tasks.
Loren
found this also,
BCS Sky Jump V950 Dualsteer
"The BCS Sky Jump is a specialized tractor with front pneumatic wheels and rear rubber crawler tracks. This dual configuration provides the units the handling qualities of a classic tractor with pneumatic wheels as well as the stability and traction of a caterpillar.
As a matter of fact, the traction of the Sky Jump, depending on the terrain, can exceed by 60% the one of the tractors with pneumatic wheels and if used on steep slopes it has a higher side stability which allows the tractor to work in espalier rows, generally sloping downstream, while perfectly following its direction even if combined with heavy tractor-mounted attachments."
