Help identifing old John Deere yard tractor
If it is a three cylinder it is most likely a 300. The Ag counterpart is a 1020. There also was a 301 and a 302. If it is a four cylinder it is most likely a 400 which would be a 2020. Tom
Well, your definition of a yard tractor is not the same as mine. You must have one heck of a large yard.
That would be an industrial/construction tractor in my mind.
Loren
I'm not expert, but I do own a 301A which looks somewhat similar.
I've got an old Hot Line Farm Equipment Guide which lists the 300 and 400 model tractors----but none of the serial number are in the same range.
I Googled Type 7300 and found several hits that show a model 7300 loader that was standard equipment on the model 300 tractor/loader/backhoe. Try this site for a little more information.
https://www.deere.com/en_US/docs/construction/non_current_products/backhoes/300.pdf
(quoted from post at 17:58:44 02/21/19) Well, your definition of a yard tractor is not the same as mine. You must have one heck of a large yard.
Loren
Probably means "yard" as in Industrial Area. Confusing usage here in USA because the word can mean both things--your front lawn or Industrial place. Far as I know, Brits call their yards a "garden."
Adirondack This is not a jab a put down or a low blow but it took me about 5 hours to clean up the snow in the cattle yard and stack yards the other day
