Midway
Installed a new radiator on a farmall B. Afterwards I read it was for a pressurized system. My B does not have a water pump. Will this be problem? It fit and part numbers said it replaces the original parts number. Thanks for any replies.
Pressurized means the radiator cap seals well enough to the point it develops pressure inside the system. This is caused by the expansion of the water due to heat. It doesn't mean your tractor now requires a water pump.
What it does mean is that now the pressure can find leaks somewhere else if there are any weak points.
The block and hoses can deal with the modest 5 to 7 psi of a pressure cap. The radiator was the component that could not. the new radiator will stand the pressure, so a pressure type cap is fine. level of coolant should be about 1 inch above the cores, looking into the cap. Jim
