bobbie01
New User
I bought and old Terramite T5? from the 1980s? I've used it for four years now the 18 hp Briggs is worn out going to replace with Harbor Freight 22HP needing info on hydraulic pumps a supplier that want rape you or rebuild info opinion on all is appreciated
on motor hydraulics or any other thing on this little loader back hoe
They used a simple hydraulic pump to power the hydraulics for the loader and hoe that is plumbed into a
hydraulic motor coupled to the rear axle. Unless yours is losing forward/ reverse travel or the loader or
hoe are getting weak,change the fluid and filter and you should be good.If your engine is weak and unable
to maintain rpm the hydraulics will seem weak also as they are rpm sensitive. The pump and motor can be
rebuilt if needed by a reputable hydraulic shop,it won't be inexpensive,but it will be considerably
cheaper than rebuilding a hydrostatic pump and motor.
