david nichols
I have a jubilee that previous owner disabled the thumb starter switch and put on a push button.
I installed new thumb switch, but no go. (Also been switched to 12 volt in past years, with a 172 engine) the solenoid has 2 large terminal, in from battery, out to starter, and one small terminal, to the thumb switch. I'm thinking the small terminal should be hot and when thumb switch is pushed, grounding it, then power goes to starter ? Currently there is no power to this terminal...bad solenoid? Or am I wrong in my thoughts...
I know this has been covered in a thread somewhere, just can't locate it...thanks in advance !!
