Ford 3600 - Battery Cable Holder/Bracket
Does anyone know what this part is called and where I can get a replacement? I am replacing my 1/0 GA battery to 1 GA battery and the bracket/holder ends up being too big and cannot hold onto the thinner 1 GA cable. I could improvise by adding tape around the cables, but would like it to be more original. Thanks!
I know hydraulic shops have guides to keep lines from rubbing you might find something that will work for you
If you can not find a new holder how about cutting a short length of heater hose and then slicing it
lengthwise and slide it over the wire no one should even notice
Harbor Freight has a little assortment in plastic box that would have what you want. Me I would just go to the vise ,cut of a little and drill another hole, 10 minute job.
I doubt you'll find anything shaped like that, it was made just for that application.
You could get some flat strap, probably have to cut it off a piece of sheet metal, experiment with wrapping it around various size pieces of round stock, try to form it as best as possible. Then dip it in Plasti-Dip for the black insulated part.
Seems like a lot of work for something that close...
Why do you want to down size the cable?
(quoted from post at 16:06:54 02/18/19)
Thank you everyone!
