'99 Yukon Accessories
doorman
Got a '99 Yukon that the accessories only work intermittently. Already replaced ignition switch. Is there a relay I don't know about? They work fine sometimes,
then just quit. Any help or suggestions will be appreciated.
When the ignition switch was replaced, were all the terminals clean and bright?
If one had been hot, the female connector up in the plug will be loose and soon fail.
Otherwise it will be a lose, corroded, hot connection somewhere...
You can go on Auto Zone, register and get access to wiring diagrams for most vehicles. With that you can start tracing the circuit.
But, it will be a matter of catching it in the act, or finding a bad connection.
